Just done the profile - forgot about it.
I certainly have had problems in under extrusion, (something in the nozzle), that seems to have cleared now.
I am about half way through a spool of filament, is it necessary to try and uncoil it? It seems to be quite highly coiled as it nears the centre.
John
Which printer do you have? Please update your profile settings to indicate this. Also update your country/location as advice changes often depending on the country.What you describe can happen but usually if there is a layer like this it can also be caused by underextrusion due to temporary tangling filament, temporary cold layer (often due to fans coming on) and similar things like that.
gr5 1,843
