Just received my UM2go. Small floating part inside
Posted (edited) · Just received my UM2go. Small floating part inside
Please tell me if the second small blue ring (2nd picture) was detached from a component or it's just a spare part.
Many thanks.
    Look at the first picture and then the second.
    You should be able to guess where this blue ring belongs to. :)
    A hint, it is white and keeps a flexible Tube from getting drawn out.
    It goes on the bowden tube on the print head, just like the other end at the feeder
    Posted · Just received my UM2go. Small floating part inside
    It sure does, on top of your print head, around the bowden tube, under the white ring.
    If you have found an answer on your question, please select a 'best answer'. This will help future readers to find the right answer as fast as possible.
    Thank you! :)
