with that layer hight and speed your really pushing it To much for the stock feeder. So slow down or reduce layer hight or print an alternative feeder.
You may also encounter an issue with not enough top layers. What top/bottom thickness did you set? Rule of thumb set at least 5 or 6 layers to close the top surface... so In this case 0.3 X 6 = 1.8mm
Labern 774
Hi, What temperatures were you printing with?
were you printing with the default speeds in expert settings?
