I guess its a hardware issue. If suddenly the printer doesnt work anymore it's usually not a software issue.
You could try putting the heater cardrige (and temp sensor) in the slot for the second extruder and check if that works. If it does work, your electronics is broken. If not, its probably the heater cardrige.
1
SandervG 1,518
@Nallath, do you have any tips for Roald?
