Dim3nsioneer 557
Yes, there is a small bulge before the narrowing (the latter of which probably comes from pulling out). This bulge might be an indication that there is a small gap between Bowden tube and Teflon coupler. Checking the Bowden coupler as suggested by @labern is certainly the best thing you can do. Do also check the Bowden tube itself. If it has deep scars around the spot the Bowden coupler you might want to consider replacing the Bowden tube (you could actually also cut off a few mm to make the Bowden coupler holding the the Bowden tube at a clean spot, but you would have to cut very accurate to have a proper fitting between Bowden tube and Teflon coupler again).
Labern 772
It's probably the ptfe coupler and may need to be replaced. But also check and make sure the 3rd fan at the back is on 100% of the time. If this stops it can cause these issues.
