Problem with HBK for UO
Posted · Problem with HBK for UO
My Ultimaker original worked fine until after 8 months of waiting i got and installed heated bed kit.
The problem is that when everything is connected as it should be, ulticontroller shows MAX TEMP ERROR.
If I disconnect the black wires that goes from heated plate to HBK PCB - ulticontroler shows 70 C/0C (the bed is cold, but it shows like it has 70 C).
If I disconnect the cable that goes from Ulti. shield pins TEMP3 to HBK PCB pins BED I can heat the bed but cannot control the bed temperature (it heats up to max).
I don`t know what is wrong. Is the HBK PCB destroyed? Is the whole HBK design so bed?
    Is it possible you mixed up the wires for the temp sensor (thin black ones) and for the heater pcb (thick gray ones) when fasten them on the heated bed?
    No that is´t the problem cause i have already tried that.
    If I have everything connected only the black wire that goes from shield to HBK PCB is disconnected i dont get max temp error, but i also have 0 C for bed temperature. As soon as I touch the connector with black wire a get the max temp message.
    If you tried to heat up the temp sensor I guess it is destroyed..
    But how to check if temp sensor is destroyes and where is it located (on HBK PCB or Ultimaker shield).
    I have checked resistance between temp sensor wires and on a resistor of heated plate and they both show about 112 Ohm-if that has any importance.
        • 24 replies
