Cura 15.06 / 15.04: Spiralized Vase, Stutter Scar
lars86
Posted · Cura 15.06 / 15.04: Spiralized Vase, Stutter Scar
As the new Cura Engine was built to be enhanced by plugins.
Just a quick correction; The Cura GUI is built to be enhanced by plugins. The engine has no such feature (yet... Dont expect it very soon).
    • 3 years later...
    1 hour ago, goose_busters said:
    how can you turn on vase mode in cura 15.04.6 I have a creality CR-X and only has a config for an older version of cura, I'm also fairly new to 3D printing.
    From the menu choose: "Expert" -> "Open expert settings...", and enable "Spiralize the outer contour" in the "Expert config" dialog.
    Good luck!
        • 27 replies
