Just a small note, bed at 60C is for PLA plastic. Different types of plastics require different bed temperatures.
Thanks for the tips gr5!
Was using PLA and bed was default at 60 deg, was using glue but will try the wet wipe next time with the brim setting
Tried this afternoon printing again while watching and it started to candy floss but noted was not extruding properly, so think it missed a layer or 2 then was printing in thin air. Did a Atomic clean and has been fine so far.
Check your model in cura "layer view" mode. It may be that there are some layers that print nothing. That's a problem. Perhaps your model is bad, or is not solid or maybe it has walls that are too thin to print.
Maybe include a photo of your model in normal view, layer view, and stop the printer once it starts making "floss" and take a picture of that also. Right now your "floss" is hiding the important things underneath.
gr5 2,192
Could be lots of things but typically it's because the part fell over. I recommend not leaving alone for more than 20 minutes until you have more successes. You are lucky the part didn't drag around with the head and then you can get a massive ball of molten plastic.
Did you do bed at 60C? That's recommended for good stickiness. Also a very thin layer of that glue stick. Wipe the glue stick on the glass, then use a wet tissue and spread it around extra thin.
Also use the Brim option. Also make sure the bottom layer is well squished onto the glass - I can't tell from this photo but you want the very first traces to be wider than tall. If not just rotate all 3 leveling screws by 1/4 turn CCW. I often do this at the start of a print (fine tune leveling).
Edited by GuestLink to post
