If you're the one who designed the part I'd advice you to just go ahead and create support yourself, it'll give you less head aches. I think a thin, 0.5mm, wall from the lip of the snap feature down to the rest of the model with a 0.2mm spacing on "each side" would allow the printer to bridge the rest on its own and it will remove with basically no trace.
1
peggyb 171
click the little white box behind the "everywhere" support setting, this will take you to the expert settings. Look at what angle is noted there, I guess the default is 60. Change it to zero and look if something changed in the layers view.
