AMAZING Robert (as usual!!)
The ZERO infill fixed the jumping around while printing layers but on the last layer there is again strange "spot filling" ... my model should be flat at that point as I was playing with taper edges earlier and did not really produce good results (have to retry as it could be related to the infill too) but that B letter STL file had a flat "top"/final layer so I do not understand why CURA slice it like this
Let me know if you need to see more parameters...
And again, thanks a lot this is really good help and very appreciated!
IRobertI 521
There is nothing wrong with your model. The problem you're running into is cura trying to fill in teensy tiny areas where it thinks you need infill. This is why you always want to check the layer view (click the button in the top right corner of the 3d view).
The red lines are the "shells" of your print, the outer contours. The tiny yellow dots is the infill and the blue lines are rapid moves that the head will make.
In this case, simply setting infill to 0% will "fix" your issue since the base of the print is thin enough to become solid with the top/bottom layers.
I wrote a few more notes about this here:
http://support.3dverkstan.se/article/30-getting-better-prints#solid-layer-fill
Edited by GuestLink to post
