I think your idea of pausing and adding a layer of tape is a good one. You can build a simple scaffold into the model with space allowing for the tape. Then disable all supports in Cura.
Pause at the top of the scaffold, add the tape, maybe also use tweak at that height to change printing speed (slow down for 1 layer maybe) and increase flow rate (maybe 105% for 1 layer).
That's what I've been doing when embedding a horizontal steel plate into a part: Pause, drop the plate onto a scaffold, push some extra filament through while it's paused to make sure it's all primed, then resume. Tweak slows everything down 50% for a layer
mastory 42
Anyone? anyone....
I hate to bump my own thread, but seeing as this is a prevalent topic for me at the moment if I don't I'll be stuck with traditional means even if a better solution exists.
Is there a way to print two objects in the same space with different print parameters simultaneously?
Can anyone else see the utility in it?
Thanks.
