Maybe you can add some gcode
You will need to set it in the start g code.
For example:
G1 Z(number here) // moves bed
G92 Z0 // set this position as 0 for z
Not tested but I think that should work?
For example:
I agree, but for a different reason. I would like to print on top of an existing vacuum molded template. Using the Printer to make changes to the molded part rather than waste the time printing the entire thing.
I think we all Know that we can edit the g-code, but a more reliable and user friendly method would be a software change.
It's a simple code you can add. If you want that by software buy Simplify3d
For the time being I am simply zeroing the build-plate at the molded part height. But will definitely look into the Simplify3D
I pointed you to s3d because it has the option you want. Ofc cura someday will have that too. But to have it 'now' it's your best chance. Also the lastest version added a lot of stuff (that looks like 'inspired' to say the least) that make's it even more cura-friendly. Anyway cura still it's my first choise to print&run. On s3d you must give him a very clean stl and learn how to use the options but when you do, it's worth the money. Specially if you want to do stuff that it's a bit less normal. Like multiprocess, scripting, getting a perfectly clear first layer without scraches. Etcetc
tinkergnome 917
http://wiki.ultimaker.com/CuraPlugin:_XYZshift
...but read the comments carefully.
