tinkergnome 927
The value is a bit weird... M92 sets the steps per mm AFAIK.
I'm afraid that Marlin ist not prepared to control more than one extruder at the same time. It supports only one active extruder at a time. How did you achieved this?
If i get you wrong, and the extruders are used successively - the right place for this command would be the toolchange sequence (right after "T0" resp. "T1").
But to be honest: i never used Repetier Host...?
gr5 2,194
Unfortunately I only just approved this and now it's burried under 16 hours of posts. You should have marked it as a question so it shows up as "unanswered questions". I'm not sure if you still can. If not just post again and make sure it's marked as a question. Anyway the next time you post a question it will be at the top of the community list.
