@tinkergnome Sorry. I can't keep everything in my head, it's too small Now that you linked me to it, I do remember that I've seen it before on Youmagine.
Well, 2 weeks in to the overhead feeding. Still using duct tape and zipties at this point. Trying to find the optimal settings and angle. I have found that cutting 8" or so off the bowden was too much in my current configuration. I'll also have to switch to a quick release style feeder. I just can't get enough leverage to manually push the filament through when changing. The dependability factor is outstanding. A few 24 hour prints and I know it's just going to keep feeding.
I've designed arms that mount to the the wall that will hold the spools and feeders, as well as integrated bearings to guide the filament to the feeder. Will keep you posted.
Edited by GuestYes! Close to what I was thinking.
I have used one of these carts before, liked it but still think of some improvement could be done.
Also think this would stop some other problems. Moisture, dust, ease of filament change.
It's can be a pain in the Bum to change filament when you can't get to the back of the machine.
http://www.thingiverse.com/thing:954675
Interested is seeing what others have done along these lines.
Thanks Ed
tinkergnome 926
Calum Douglas made this for the UMO
Perhaps you can seize his suggestion....?
@IRobertI - i can not believe that you missed the "The Ultimaker Spacer" resp. "The Ultimaker Table" (Adobe Inventor and dxf files included).... until now...
Should be easy to adapt for the Ultimaker2 - if needed?
Edited by GuestLink to post
