Either it *always* goes down or the directions are backwards. Hopefully the later. Let's figure out which and then fix the problem.
To figure out which you need a way to move it both up and down and see if it's backwards or if it always goes down. There may be a way to do this in cura or from the ulticontroller - not sure. But if it were me I would try pronterface. It's a free download here - you connect to the printer with a USB cable and move it small amounts - you don't want to break the glass. 1mm or 5mm is plenty:
http://koti.kapsi.fi/~kliment/printrun/
Once you know which (always down versus backwards) I'll tell you what to do next. Also please mention what country you are in within your profile settings as parts and other things depend on the country.
While using the bed levelling wizard in Cura, if I press either of the up or down buttons it always goes down and by an amount much larger than what I told it to, yet this morning when I was fiddling with the Ulticontroller for a few minutes before I left for work I discovered that its auto home option raises the bed just fine(actually a bit too high, need to lower my Z switch, whoops), which leads to the assumption that it's something wrong with my Cura install, not with the printer.
I'll give Pronterface a try when I get home tonight, cheers.
gr5 2,189
Edited by GuestLink to post
