You can set the temp up to 15 degrees lower than max temp in the Configuration.h file. You have to make a custom Marlin build. So if you want 310C to be the max set the max temp in the Configuration.h file to 325C and then rebuild Marlin.
Thank you for the quick reply... I am not too familiar with the process of "rebuilding" Marlin. Are there any good internet resources I should check out pertaining to this?
gr5 2,225
