Hi, I know this thread is sort of old, but I just finished putting my umo+ together and I'm having the same issue. Was there a solution to this?
hi,
make sur you have the good firmware (re-upload it with Cura)
the pictures of lassesp2142 look good
Edited by GuestA bit off topic. It's so great to see 2.1.4 boards with the new UMO+
Great news for better future um2 hotend use =)
Also yea, reupload the firmware, that what's looks like when a board has um2 firmware on the umo+ display.
Also since you are installing your machine. You can get a um2 led strip from any ultimaker distributor, it sticks and fits perfect and works like a charm when you use the Amedee firmware builder https://bultimaker.bulles.eu
And how it looks the leds on umo+ when installing it:
https://ultimaker.com/en/community/9607-leds-on-umo-out-of-the-box?page=3#reply-115149
Did you read the post right above yours? Please supply more information about your problem. I can't tell you how many times people say "I have the same issue" but they have a completely different issue.
Sorry about that. I'll try to be more thorough in the future. I just updated the firmware and it worked like a charm.
gr5 1,841
Your symptoms are what I would expect if one of the ribbon cables was backwards. Unfortunately I don't know where the red stripe is supposed to go. And how do you know which cable is which?
I have a UMO and a UM2 but the UMO+ has a mixture of equipment from those 2 machines so I'm not sure how the ribbon cable is supposed to go.
also it looks like those 2 cables each have a backwards crimped ribbon - which shouldn't matter as long as you are consistent with the red stripe - but still - strange.
Where in the manual (I have it open) does it say which ribbon connector goes where?
