Yes, I agree about STL - I'm new in 3d printing, and so far always used old STEP format (all our camera parts, such as for Eyesis4pi have the STEP files posted). Noticing that 3d printers use STL format (never used it before myself) I just got a wrong idea that this format is newer and more advanced than STEP.
Then the question is - why Ultimaker does not support STEP? We send our files to machine shops here in the US, and to China - all CNC shops understand that format.
As for million-faced design - I'm new in 3d printing, but I designed many PCBs. And the software that "thinks" in terms of straight line approximations of arcs is just not good enough (not going into details). It still could be OK if Cura can do this conversion as a last step, but how can I import a real cone to Cura? For 3d design we use proprietary software (running on GNU/Linux), and there are no configurable options for STL format. Are there other good STEP -> STL converters that support "1000 sides"?
gr5 2,225
The STL format doesn't support arcs - that's the most common standard that all the slicers accept. I don't know any slicers that support arcs either. marlin I think does support arcs maybe? I think you can enable it in a compiler setting maybe? Maybe not. I'm sure some of the newer "cell phone cpu" based printer controllers like beagle bone and tinyG have the cpu power to support arcs.
How about 1000 sides? Is that enough? At some point the printer is adding more error than the error of converting a circle to edges. A million polygon part to be printed is not unusual.
