You know that you can see instant results to your settings of this kind of thing by looking at layer view, right?
Hi, gr5,
Thanks for the response. First, no, I meant "skirt". I can get the brim to print, but I want to print the skirt to prime the hot end before it even gets close to the model.
How do I find "layer view" in Cura? I'm using 15.04.
Thanks!
Jack
Ah, gr5, I found "Layer View", and that is helpful. However, I still need to know what settings to use to get a skirt to print.
Thanks again,
Jack
Go to Expert Settings in the Expert Menu to find Skirt settings.
Under "platform adhesion type" choose "none" which is the equivalent of "skirt". Then click the ".." button next to that to contorl skirt settings.
You may have to disable support to get the skirt to work - not sure.
gr5 2,210
I think you mean brim - it's on the first page under "support". Brim touches the model. Skirt doesn't. A "skirt" is just something where it goes around the model once to test out the extruder to get things flowing and you can also use it to check and adjust your leveling at this time before it starts your proper parts. But the skirt doesn't touch the model. The Brim does.
