The feeder has a built in safety feature where it reverses (kicks) back a few mm if the pressure build up becomes to high. This stops the feeder grinding the material. To don't be scared to add more tension. By memory my spring length is between 11 - 12 mm
- 1
gr5 2,192
with "move material" it's easy to go much faster than the printer can normally print. I don't get grinding material though - your tension is probably too loose. The forces in there are impressively high - about 10 pounds or 5kg force is being pushed on that filament before the feeder skips backwards (which you want to happen during move material versus grinding).
Here are some photos giving you an indication of the desired tension - the filament on the left had not enough tension. The one on the right might be a little too much.
JohnK 30
Thanks for the quick reply..
The markings on mine are kind of in between the two examples you posted. I'll take a picture later on and post it up.
I might try and go tighter, just a little scared of putting too much tension on the feeder. I'm using the default yoke on Roberts feeder and my tensioned spring length is around 12.5mm.
Thanks
