a;so try and keep the filament in a sealed container or make sure it stays dry and dust free
Get the sewing machine oil and lubricate the rods.
I forgot to do so after 6 months of disuse. While it worked, it was NOISY!
I just use a small piece of cotton (cotton ball), dribble some oil onto it and work it around all sides of the rod. You'll notice you clean some debris off. Again, just a little goes a long way! Disable the steppers and slide the print head around.
Thank you all. That was really helpful.
Just one last questions. If I use it every couple weeks, is it enough to keep it "oiled"? I don't want end up lubricating the shafts and the rods too much.
It should be OK. You will know when it's drying out to much as the shafts blacken off a bit.
Oiling is a part of regular maintenance so just do a quick check before printing every time.
1
What labern said, you'll see and hear when the shafts need it!
neotko 1,417
If you do atomic pulls to remove filament residue on the head and keep the machine covered to avoid dust on the shafts it should be more than ok. Also oiling the shafts to keep all in order it's always nice.
