I just unscrew all. It woobles. Also released the motor so there's no tension from the short belt.
I the bushing I think it looks okey. I also took out the 2 little tensioners of the belts. Woobling :S
Btw I just installed a new head central block. But to remove that from the equation I took it out and left the central x/y shafts free. Woobling..
I will start to change pulleys of order I suppose.
LePaul 310
What do the bushings in the slider block look like? If the shaft is straight, something in there must be causing that rise?
