I have the same issues with the new Cura 15.06.03. Can't find the tweakatZ plugin and is there some kind of auto adjustment for bigger parts? Can i switch it off? With the old Cura, I rotated the bigger parts diagonal on the printbed. Now the parts are down-scaled before I can do something.
It does save a print profile of sorts; it remembers the changes that you made. We are working on 'real' print profiles, i've already created a chunk of the functionality required for that.
The issues dim3nsioneer has with the post processing were already in the plugin, as it uses the same json structure for settings.
Dim3nsioneer 558
@nallath is indeed working on a postprocessing script plugin for the new Cura. He calls it a quick design but it's not too bad. There are just a few details missing which I hope he can add.
But the most important thing concerning the OP is that this plugin already has a PauseAtHeight script...!
Edited by GuestLink to post
