Youe case looks good indeed. You clearly know more about this than me. I would just buy a sd extension and make the fit fixed and place the new sd card loader on a cool spot. Also it's a fast way to buy a new connector if you are going to solder it.
I would not say that, but thanks...
That's actually a great idea to have an extension for the sd card reader slot. Let me think about that.
1
- 1 year later...
Resurrecting an old post...
Martin,
Did you ever solve the broken SD card slot problem? My SD card slot just broke on my 1.5 month old UMO+. I like your custom UltiController case, but I'd like to just get my printer working again.
I guess I'm still in the warranty period, so if there isn't an easy fix on YouTube or something, I'll contact support.
- 3 weeks later...
Sorry for the late reply. No, I never solved the issue, I worked around and it works for me...
Thanks for the response. I ended up calling support and they sent me a replacement UltiController board. The UMO+ warranty period is one year, so it was no big deal.
neotko 1,417
If you want to replace it you could also just buy a cheaper ramps full graphics controller like reprapdiscount. They go for 20-30€ and you can print the box (many designs on thingiverse or youmagine).
Search Full Graphic Smart LCD Controller Ramps compatible.
And with @amedee firmware builder it's very easy to activate that:
https://bultimaker.bulles.eu
martin-bienz 36
Hi @Neotko
thanks. I allready have one of those (I forgot to mention that, that's right) and I now how to change marlin to make it work (amedee's firmaware buider is fantastic btw, thanks for that!). I bought the full graphic smart lcd controller for another project... small cnc mill.
But I actually like the "small" footprint of the original UltiController... so if it's doable, I would like to fix it / replace it (also would like to keep my case
). I might just desolder the SD card slot and replace it...
Best Regards
Martin
