It should have a nice internal nozzle shape like the picture in THIS guide.
DidierKlein 730
Either you pull at a too hot temp or too slowly, the cold pull must be done quickly with a firm pull
Thanks for the answers. I only use PLA and I pull it at 90 degeree but i might pull it too slow. I will try it faster
The "bubbles" you see at the side of the plug can also be because material is oozing as you're waiting for the nozzle to cool down. I usually keep a slight bit of pressure on the filament during the cool down so that the chamber remains full until the material is no longer oozing out.
Labern 775
looks like it is stretching as you pull
try and let it cool down a bit more then pull.
what temp are you pulling at? i pull at 70deg for pla
