Yes, it's version 15.4
I may try reloading the software and see what happens. I also see they have version 15.4.02 available for download. So if 15.4 doesn't work I'll try the '02 version and see if the problem goes away.
Otherwise, it's quit the program after every print. Not a big bother I guess.
Thanks for the reply.
gr5 2,071
What version of Cura? If this is in 15.6.* or newer then this is a total rewrite of Cura and the developers will want to know about this bug and please post it on the github cura issue tracker. (sorry I don't have the address - traveling today)
But if this is 15.4.* or older that project is pretty much over. Also if this is 15.6 or newer I recommend you stick with 15.4 for now as they are still working out bugs with the "newer" cura.
