255 is a little bit hot for ABS - that is hot enough to burn bits of it and also hot enough to cause a nasty clog if you print too slow. I suppose if you are at 3 cubic mm/sec it might be okay (to check printing volume speed hover mouse over the print speed - it's a combination of nozzle diameter, print speed, and layer height).
Also the variation on temp sensors can be + or - 10C. So consider printing at 250C instead. Or even 245C. I can't go below 245C or I don't get good layer bonding.
Also 70C bed temp is not hot enough to prevent warping corners off the bed for ABS. I recommend 100C bed temp and enclose the front of the machine if not also the top. Although if your part is sticking to the bed then I suppose you don't need to worry about the temperature thing.
1
ataraxis 51
have you tried to clean the nozzle (atomic method), maybe thats some old PLA?
