You could try transparent XT, that turns whitish semi transparent, when you use infill.
Not my pic:
Edited by Guest- 1
Not my pic:
Edited by GuestThis may be what you want (not my pic, nicked from the Taulman site)
[media=5671][/media].
The bottom half is Taulman t-glase - which I use. The top half is the same filament but covered with XTC-3D - which I also use.
@xxxprod: As you may (or may not) know, Ultimaker printers are open source. That means that they published drawings for every part of their printers, including the Ultimaker2.
So the only thing one has to do is to check the drawing of e.g. the left panel:
https://github.com/Ultimaker/Ultimaker2/blob/master/1232_Left_Panel_%28x1%29/B1232-B2P-D.PDF
And here is your answer: Perpex frost. Good luck with your project!
Thanks for all the hints and specially to @Dim3nsioneer for the concrete answer!
stu_le_brew 42
can't answer what the materiel is for the sides but I have been getting some great clarity with HD Glass from formfutura.com. They claim 90% plus clarity, it is less clear with higher temperatures, also its even FDA food and drink contact approved if thats important for your needs
