@DidierKlein, you are right, the models are largish. Still amazes me though.
@lRobertl, I did try enclosing the printer and printed at 260C, but it did not make a huge difference. PLA can clearly take way more of a beating than ABS. On the other hand, for master models that will be used for casting, I use ABS since the surface finish is way superior for some inexplicable reason.
cloakfiend 996
I say if it works, keep doing it until it stops working. Its all magic to me. Never really thought the fans did much to be honest considering mine sometimes sound like they are dying. and it was all down to ambient temps, but hey I really don't have a clue. Cooling temperature must be relevant to some extent, but where they are most relevant is another matter all together.
DidierKlein 730
PLA without fans will probably print fine, but don't try it with small prints, i guess you print some large models, the layers probably have time to cool enough
IRobertI 521
Like Didier says, it's all down to the model you're trying to print. A large(ish) box will print perfectly fine, but try printing something small and pointy and you'll regret not having your fans on.
As for the delamination of the ABS. Have you tried enclosing your printer? That'll help keep the print at a higher temperature until it's done to lessen the impact of the shrinkage of ABS. Might also want to consider raising the temperature if you're not already at 260C.
