Posted · UMO Original Heated Bed questions
I finally ordered my Heated Bed Upgrade and have a few questions about having a heated bed...
1) What temperature to use for most prints?
I use ColorFabb PLA/PHA and see they have a few suggestions, but I also wanted to hear from the community on what has worked for them.
    Posted (edited) · UMO Original Heated Bed questions
    on PLA/PHA I use 55 or 60°C. I think everything between 50° and 65° will work. When you want to avoid sagging you may go to the lower end.
    May be this is helpful too: http://support.3dverkstan.se/article/30-getting-better-prints#heated-bed-temperature
    Edit: I only use Colorfabb or faberdashery
    I appreciate your reply.
    I ordered the Heated Bed Friday morning from MakerShed and when I checked today, it now lists the item as back-ordered. (I am hoping I got the last one...or not waiting for weeks for one to ship...!)
    I've become a ColorFabb Snob....I love their filaments!
    60 degrees for PLA works nicely for me... Printing on a glass plate covered with PVA glue diluted with water (1 parts glue, 5-10 parts water)...
    I heat up the plate to 60 degrees with the "Preheat PLA" option and apply the PVA/water solution with a sponge... The heat quickly dissolves the water, leaving a thing film of glue.
    Having an extra glass plate is a nice thing... you can take a print out, and wait for it to cool... Meanwhile you just slap in a new glass plate and print some more.
    How long does that coating last?
    Right now, I have too much adhesion with the acrylic bed and blue painter's tape. I wipe it down with rubbing alcohol (otherwise things won't stick)...and after a print is done, getting the print off the build plate is a struggle. I have to remove the build plate and gently pry a scrapper under the print and tug/pry away. This rips the tape and requires a re-apply of tape, wipe with alcohol, etc.
    Heated kit arrives Monday. Can't wait to try
    btw: I use no glue, no 3dlac, no voodoo - just print on glass and everything is fine. This works for PLA/PHA, colorfabb XT and bronzefill. For copper- and brassfill I use bluetape, because these materials are sticking so well that it is impossible to remove the part from the glass without breaking it.
    oh, Monday is bad :(
    May be it will arrive Saturday - fingers crossed ;)
    I was hoping by the weekend, when I have some free time to do the upgrade.
    It lasts maybe 2-3 prints, all depending on how large they are etc (often I'll also rearrange smaller prints to fit onto a nicely coated area of the bed).
    But really its so simple to apply and wash off that I don't see it as much of a problem.
    Ive heard of these people that print directly on glass, which sounds wonderfully simple... The times I've tried it, Ive gotten absolutely no adhesion at all, so I gave up on that.
