yellowshark 153
Yes I am sure we have all had your problem at some stage. In addition to what you have done...
When you say "recalibrate" I assume you mean bed levelling; have you checked the nozzle tip to bed distance too? When it has happened to me it has been one or both of these causing the problem.
Bed temperature; I would be 99% sure that your temp. sensor is measuring the temperature of your bed, not of the glass plate. Have you used an IR temp gun to check the glass temp.?
Also depending on the temp. sensor and its location, if the centre is showing the right temp. it can take another 10-15 mins for the perimeter areas to get up to temp. But if you have printed this model before I suspect this point is not relevant.
Are you using the same filament as before?
Have you done a manual feed beforehand to check that the filament IS flowing OK i.e consistent and not thinner than before?
rigs 735
Hi
Check this thread :
https://www.3dhubs.com/talk/thread/perfecting-first-layer-tips-and-tricks
