Thanks nallath, this will be the largest build I have done and thought I would just do a quick check here before finding out the hard way.
- 4 months later...
On a related note , the stated ultimaker 2 max volume is 23 X 22.5 X 20.5 cm . I imported my design into CURA and the max dimensions actually for x,y was 20.7 x 19.6cm. When I scale to 100%, CURA greyed out the object just like the previous post said. Is there a way to reach the max dimensions for the Ultimaker 2? Is there a way to reach the stated max dimensions without redesigning ? is there a parameter or setting somewhere that will give me the dimensions I designed to?
set the skirt and brim to 0.
1
Thank you that helped, setting skirt and brim to 0 I was able to get to 225 mm of 230mm in x direction. is there one more parameter that would give me the last 5mm? Thanks again!
look in the machine settings, but beware of the clips and the head hitting the sides, if you change something there.
But did you reach your max. in y yet?
1
Thanks guys, I maxed out the scale, brim and skirt at 0 and it printed just fine.
only reached max on x. I have some lee way still in y before the object "greys out". there are many settings in "machine settings". The information bubbles help alot. However, a more detailed explanation of the settings in a glossary or index setting would really help in terms of how these settings interact with other parameters especially max print size. Thank you very much again.
nallath 1,080
If you scale to max, it does print in that size. If the model is too big, it turns gray (indicating that it's not printable).
