Oh and the clips I use to put the box on the top are on youmagine.com
Having printed several hundreds of hours worth of ABS both very small parts and pretty large (longest print was 65 hours), I think your issue is not so much the ambient temperature, since you are printing a smallish part.
First of all, all the blobbing can be down to too much or too little fan. Weird, I know, but at the moment I print ABS with the fans off. Even really small parts.
Next, the temperature does not have to be so high. Try printing at 30/mms with the temp at 220C - 230C, layer height 0.1mm.
ultiarjan 1,222
For abs you need to enclose your printer to create a "heatchamber". I use a perspex plate for the front and a curver box to put on the top.
