Are you sure it's not just something trivial like the filament getting caught on one of the transitions in the head? It's quite common for the filament to get stuck on the transition between bowden and PTFE. Cutting the filament so that it is pointy helps with this. Sometimes giving it a good shove at the feeder end can also allow it to get past this point.
Wonder if your PLA is a little over size and getting caught in the head.
Also cut the end off. If I do a 'filament change' I often get a small blob on the end of the filament which is quite a bit larger than 3mm.
- 2 weeks later...
Update - it works!
So I put the PLA back in and removed the bowden tube when I initially forwarded the material. I let the filament extrude several inches through the end of the bowden tube, then manually inserted it into the extruder. I gently forced it through the nozzle until the bowden tube was back into place, and then everything worked normally! It was getting stuck in between bowden tube and PTFE, like was said above.
ultiarjan 1,222
Nr1 check your ptfe (the white thing) In the head. Take it out and check for damage. Abs is much more slippery so it's very well possible that it's still possible to print abs with a damaged ptfe.
There's tons of info on this forum on how to do it.... just ask again if you need more info..
