I get 404 error going there too
What OS do you use and what browser?
OSX - Chrome v46.0.2490.80
That link you gave is still showing 404 for me as well. I wonder if maybe you have a working (cached) version of that page SandervG ;-)
Have you tried opening that page in an Incognito Window (Chrome) or similar so that it doesn't load the webpage from cache?
D'oh! .. 404 :(
Will address it Monday morning.
Seems like the link is wrong, this is the correct URL:
https://ultimaker.com/en/support/view/17812-ulti-evening-maintenance
Indeed it works with that
404 should not be influenced by browser. It's usually a server issue or a broken link.
I could be completely wrong, but if SandervG had a working version of that path cached, then wouldn't the browser try and load the cached version instead of hitting the server? But maybe "all" browsers always hit the server to check for the status codes before loading from cache.
Could happen, i'm not quite sure how most browser do the caching. I think in our case the company network does some caching aswell. This is why you test sites with ctrl+f5 for refresh, as that force reloads a page.
SandervG 1,499
Thank you for mentioning. Can you double check if it is still the case?
I just checked and it works for me.
I end up here: https://ultimaker.com/en/support/view/17900-ulti-evening-maintenance
Perhaps it was a one time thing?
