Dim3nsioneer 556
Preheat the hotend and turn the feeder wheel manually...
Okay, thanks, that is easy. Still odd that extruding via controller or Cura disappeard in the latest releases....
You might try to use the official Marlin firmware... but you would have to configure it yourself...
Or you use @amedee 's marlin builder
peggyb 169
On the Original the easiest way is to do this by hand (I have this printer for 3 years and never used the controller for that, never noticed is was there...)
Do the 'preheat PLA' (or ABS) in the Ulticontroller and wait for the temp. to reach around 200 degrees. Than you manually turn the wheel on the back were you load the filament and turn it gently in the direction of the arrow. The resistance you feel must correspond with the flow of the filament that you can see. Do this before every print you start and if your bed leveling is good, your print will start perfect. Also great for changing colors.
