Some people do have bent ones as they can bend easily, Mine looked like yours once after a print got knocked off and bent it.
But as Robert says, Just bend it back.
As for air flow. There are quite a few printable ones that work a lot better then the standard one. You just have to find one the you think will work the best
If you want to stick with the metal one though the simple extension bracket is a good way to go.
IRobertI 513
The only problem I can imagine is if it's hitting the left side of the printer and maybe the airflow isn't ideal. Either way, it takes roughly 1.5 seconds to fix. The metal is very soft so you can very easily bend it down.
