Hi, thanks for your input!
So I ordered a Printrbot SImple Metal, the local agent gave me a great cyber monday deal which was really hard to refuse. So it looks like i'll be working on both machines which is pretty cool tbh.
I don't expect the Printrbot to be anywhere near as easy to use as the Ultimaker 2 (which is just really a great machine) but its what the budget allows for now
SandervG 1,505
Hi Young,
Welcome to the forum!
I personally have no experience with Printrbot, but I hear they are pretty good machines, especially for the value.
Obviously, since I work for Ultimaker (and you are on an Ultimaker community) I am biased. Regardless of what the Printrbot has to offer, the Ultimaker Original would be a good choice.
You say you are already familiar with the Ultimaker 2 Extended, so you know what Ultimaker products are like.
We have a strong community to back that up.
I must add, the user experience between Ultimaker 2 Family and Ultimaker Original is different. The Original requires a more hands-on experience, levelling the bed and calibrating the machine. Over where the Ultimaker 2 Family is more straight forward.
Having said this, if you go with the Ultimaker Original+ you have to do far less calibrating.
The heated bed with aluminum Z-stage is a great upgrade and allows you to print with the same materials you are used to with your Ultimaker 2 Extended.
This can be PLA, but also PLA based materials like Woodfill, Bronzefill and Copperfill.
If you don't want the heated bed it is still an upgrade in experience.
Without the heated bed it is still a wonderful machine, but know in advance that you have to level your bed a little bit more often than you had to do on your Extended.
The build is overall pretty easy, and you only need a screwdriver (which is supplied with the kit by the way).
Overall, I think both machines are good choices. Look at what company you can identify with most and look into specs like warranty, support & service and communities and do what feels best.
