Printing with a 1mm nozzle has a big effect on settings so the colorfabb ones wont apply.
You will need to up the flow rate.
I haven't printed with a 1mm nozzle only 0.4mm so cant share my settings.
@DidierKlein reciently printed out some pretty mint prints with a 1mm nozzle that he posted in Post Your Latest Print so he might be good to get some pointers from.
1
frederiekpascal 192
Did you try to print the same model with normal PLA? You can try that to see how it's printed in PLA compared to your woodfill-trial
Because, your model doesn't look like an easy one to print anyway.
I followed the Colorfabb settings they recommended and my first test print in woodfill came out just fine. (a simple marvin though
