Firmware upgrade for use with E3D v6
Posted · Firmware upgrade for use with E3D v6
Hi all
I know this has probably been covered else where, if so please direct me to it.
I have upgraded my UM2 to use the E3D v6 hotend using a mount I located from YouImangine and printed in ABSplus on a Dimension printer.
My problem is exactly what and how to I upgrade the firmware to take into account any issue raised with the upgrade eg maximun X height or other axis change, maximum temperature of the hotend etc.
I am not a programmer so am asking the experts for precise instructions.
Your help is greatly welcome.
Graeme Craig
    Posted (edited) · Firmware upgrade for use with E3D v6
    Start reading from here on how to compile firmware;
    https://ultimaker.com/en/community/7436-more-information-during-print?page=6
    In your case I assume you use the PT100 temp sensor, so no need for a firmware change there.
    Changing the maximum temperature:
    Change in "Configuration.h", look for  "#define HEATER_1_MAXTEMP"
    You need to change the PID settings to get a stable temperature, use auto tune PID, read f.e. here, or rearch the forum.
    https://ultimaker.com/en/community/7624-regarding-pid-auto-tune-with-um2
    http://reprap.org/wiki/PID_Tuning
    I got good results doing the autotune at +- 250c, not sure but I used a higher temperature.
    fill in the 3 values in configuration.h
       #define  DEFAULT_Kp
       #define  DEFAULT_Ki
       #define  DEFAULT_Kd
    I can share my E3Dv6 values on UM2, but not now as I'm not at home....
    I personally like the @tinkergnome firmware, I took this as a base;
    https://ultimaker.com/en/community/7436-more-information-during-print?page=11#reply-125341
    Regarding the max X height, I assume you mean the changed gantry height of the machine, which can cause you to knock over parts in one-at-a-time mode, you change this in the machine setting of Cura (old cura) or in the .json file of the machine, in the installation folder of New Cura (=beta).
    • 2 weeks later...
    Thanks for the reply.
    I've downloaded and installed the Tinkergnome firmware and reduced the max print size and leveled the table.
    so far so good but....
    I can't figure out how too adjust the settings you have mentioned above.
    Do I neet to run the 'PID' settings if so how? From with in TInkergnome?
    I just don't want to 'fry' anything.
    Graeme
    Hi @savak001,
    to "tune" the PID settings a recompile of the firmware is not neccessary. You get some basic instructions if you follow the links above (from Arjan).
    In short:
    • connect the printer with USB
    • open pronterface and connect to the printer
    • manually send the described gcode commands to the printer
    • the recommended values for the p, i and d coefficents are printed on the serial console after the autotune cycles are completed
    • store the new values in the printers EEPROM - (using the described gcode commands)
    • you have to repeat these steps only after a factory reset
    The PID autotune is not (yet) executable from within the firmware, but it's already on the wishlist. This would probably make such things a bit easier.
    Anyway - you've managed to change the complete hotend - those banal things should be a piece of cake for you.. :)
    Edit: the maximum allowed hotend temperature is increased to 300°C for the recent "tinker" version, don't try this with a stock hotend... and if you need to go even higher.. just ask...
    You won't fry anything.  If you have bad PID values the temperature will either take a long time to heat up or it will oscillate like crazy - like if you set it to 250C it may oscillate between 230C and 270C every minute.  Nothing serious.
    I would just leave them alone and heat up your nozzle and see how much it overshoots and does it settle in within a few minutes or does it oscillate forever.  You may be fine with existing PID values.
    You can autocalibrate your PID values.  If you decide to do this read the 2 links above about autotuning.  To execute gcodes it's easy but you need pronterface.  Download and run it here - you will need a USB cable connected to your printer from your computer to use pronterface:
    http://koti.kapsi.fi/~kliment/printrun/
    No installation necessary - just download the files and double click it to run it.
    My experience with the E3Dv6 (PT100 version) tells me you need to adjust, it will oscillate to much witht the default UM2 setting.
    or other options, if you have f.e. Simplify3D you can just use this.
    Using Pronterface I've run the PID autotune and entered the last set of P I D values (P44.33, I8.4 and D58.45) using M301 followed by M500 to store them.
    Other vaules shown earlier in the Autotune were P16.16, I1.36, D47.85 followed by P26.48, I1.39, and D125.84. Is it usual for the three sets of values to be displayed?
    I then switched the printer off and on again and sent M503 to verify the PID values. These returned as P10, I12.50 and D100.00
    Is this normal as they are exactly the same figures as stated before I sent the M303 command?
    Just to remind you I have an Ultimaker2.
    Regards
    Graeme
    Sorry another thing...
    The cooling fan for the nozzle doesn't come on when I switch the printer on as it did with the original extruder, but it works when I connect it to the connector for the dual cooling fans.
    Is this normal? How should It work?
    Graeme
    PID: no idea if your method should work, I changed the values in the (tinkergnome) firmware and recompiled it.
    Cooling fan: are you sure you use a correct voltage fan? Think the original UM2 fan is 5volt, I use a 24Volts fan from E3D so I had to take power elsewhere on the board (there's 24v output close to the power connector on the board).
    After you do the autotune and then after you set the PID values you have to do a M500 to save the values permanently. Otherwise you lose the PID values when you power cycle.
    Regarding "third fan". On "newer" UM2 printers (roughly 2015 and newer) the rear fan doesn't come on until the nozzle gets above about 40C. On older printers the fan is on as soon as you power up.
    There is a connector at the end of the PCB where the cables to the front peave from marked' Fan 19 24 Volt' would that do? I'd rather not solder directly to the PCB.
    Also I have sent the M500 command to save the PID settings. How long does it take to save them?
    Graeme
    think you mean this one .... that's indeed where I took my hot-end-fan power from... I did not like to solder either :)
    Here acutally at the other end of the pcb , but if yours works i'll use it.
    Graeme
    OK the fan now works
    But I still can't save the Autotune PID settings. Even waiting more than 30 minutes between commands the settings ar not saved after a M500. When I restart the printer and connect with Pronterface the Autotune settings are the same as before I started.
    What's going wrong?
    I forget how long it takes to save with M500 but I think it's under a second. If it was more than 5 seconds I would have remembered.
    You probably never set the PID values in the first place.
    Maybe read this:
    in summary - M303 is for running the autotune. M301 is used to set the PID values - this is critical step I believe.
    Then read up on gcodes here:
    http://reprap.org/wiki/G-code
    M503 reads back your current PID settings to make sure you set them up right. Then you can test them and/or save them with M500. After M500 you can either power cycle or simply do a M501 to read the parameters back in from eeprom and display them with M503.
    I've redone the AutoTune with Pronterface and the results are the same, ie when I reconnect after a power cycle the PIDs report the same as before I changed them.
    There MUST be something else !
    A jumper needing set to permit m500?
    I don't know how where to get the hex code from for recompiling or even how to recompile, it's an area I'd rather not get invovled in.
    I'm using the latest version of Tinkergnome firmware as linked to above.
    For your imformation here is the list of commands I've used from pronterface.
    Please note after M500 the printer was switched off and back on.
    >>> m303
    SENDING:M303
    PID Autotune start
    bias: 130 d: 124 min: 145.47 max: 153.91
    bias: 127 d: 127 min: 146.09 max: 154.53
    bias: 127 d: 127 min: 145.94 max: 154.22
    Ku: 39.05 Tu: 33.19
    Clasic PID
    Kp: 23.43
    Ki: 1.41
    Kd: 97.22
    bias: 126 d: 126 min: 145.78 max: 154.06
    Ku: 38.74 Tu: 32.74
    Clasic PID
    Kp: 23.25
    Ki: 1.42
    Kd: 95.13
    bias: 126 d: 126 min: 146.25 max: 153.91
    Ku: 41.91 Tu: 31.33
    Clasic PID
    Kp: 25.14
    Ki: 1.61
    Kd: 98.46
    PID Autotune finished! Put the Kp, Ki and Kd constants into Configuration.h
    >>> m301 p25.14 i1.61 d98.46
    SENDING:M301 P25.14 I1.61 D98.46
    >>> m500
    SENDING:M500
    Disconnected.
    Connecting...
    start
    Printer is now online.
    echo:Marlin 1.0.0
    echo: Last Updated: Sep 19 2015 22:25:59 | Author: Tinker_15.09
    Compiled: Sep 19 2015
    echo: Free Memory: 2455 PlannerBufferBytes: 1232
    echo:Stored settings retrieved
    echo:Steps per unit:
    echo: M92 X80.00 Y80.00 Z200.00 E282.00
    echo:Maximum feedrates (mm/s):
    echo: M203 X300.00 Y300.00 Z40.00 E45.00
    echo:Maximum Acceleration (mm/s2):
    echo: M201 X9000 Y9000 Z100 E10000
    echo:Acceleration: S=acceleration, T=retract acceleration
    echo: M204 S3000.00 T3000.00
    echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
    echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
    echo:Home offset (mm):
    echo: M206 X0.00 Y0.00 Z-6.80
    echo:PID settings:
    echo: M301 P10.00 I2.50 D100.00
    echo:SD card ok
    Regards
    Graeme
    I don't remember exactly, but i guess that you should get a response from the printer after the M500. Something like "Settings stored" or a similar message.
    If not, try the following:
    - make a note of your new PID parameters
    - disconnect and connect again (there should be a button in pronterface)
    - (re)send the M301 command
    - you should get an "ok." and your new parameters as response message
    - (re)send the M500 command
    - wait for message "Settings stored" (it takes less then 2 seconds)
    - Done.
    If you don't get the response messages then there is something wrong with the serial connection.
    Restarting the printer is not neccessary.
    Following on from the suggestions.
    Whenever I send a command such as m301 px ix dx or M500 there is no message received back from the printer.
    I would have thought there should have been.
    I can only connect at a baud rate of 250000 everything else reports something like this
    Connecting...
    Attempted to write invalid text to console, which could be due to an invalid baudrate
    Graeme
    A baud rate of 250000 is the correct value for an Utlimaker2.
    Are you using the printrun/pronterface from www.pronterface.com, or something different?
    Another approach:
    Copy the two commands (M301 and M500) into a (plain) textfile, put a M501 in front of it (better safe than sorry) - rename the file with an extension of *.gcode and just "print" it.
    tinkergone - is m301 case sensitive? Can he read back the current parameters before he does the m500 to see if it's the m500 or the m301 that is failing? And finally, maybe he should to a factory reset to get his eeprom settings in the correct position for tinkergone? Or is that silly?
    AFAIK all commands are case sensitive, but - looking at the script - i think that pronterface is converting it to uppercase before sending. But it's a good point and worth a try!
    A M503 between each change doesn't hurt - but there should really be a response message with the new values on the serial console after sending the M301...
    Factory reset is not silly, but will probably not help in this case. These settings are from the standard "ConfigurationStore" - i've not tinkered with it... i promise :)
    So tinkergnome it sounds like you are saying the m301 failed because it never responded with the updated values.
    Yep. I made a short test just now, it should look like this:
    ok p:25.14 i:1.61 d:98.46
    >>>m500
    SENDING:M500
    Settings Stored
    Hi Folks
    Back again after the holidays.
    Thanks TInkergnome for the firmware upgrade for the PID Autotune. Worked and stored a treat.
    However I'm getting the dreaded 'Heater Error - Contact Ultimaker' now!
    In an earlier post it was suggested setting the maximum temperature.
    Could that be my problem? There doesn't seem to a Gcode for setting this.
    The printer uses a new PT100 sensor and the E3Dv6 and printing with ColorFabb PLA.
    Regards
    Graeme
