surface is not covered completely
fritz99
Posted · surface is not covered completely
Hello !
When i print a object the surface is not completely covered.
There are a few small gaps between the printing lines.
What can I modify so that the surface gets completely flat and covered ?
please help.
Fritz
    Hello !
    please help.
    Fritz
    In Netfabb if you are designing the model and you make the length of the sides a multiple of 0.4mm it might help.
    Hi Fritz. have you set in cura 100% infill ?
    Ian :)
    Probably not since he's using Netfabb ;)
    fritz, are you using volumetric printing or the old method? I'm thinking that maybe your filament is a little bit thinner than what the built in profiles were created for and therefore the printer is not putting down enough plastic. Using the volumetric printing method and entering a precise measurement of your filaments diameter should take care of that (if that is indeed the problem). Here's a guide on how to get into volumetric mode:
    viewtopic.php?f=9&t=1009
        • 21 replies
