And if you want to modify the .step, Design Spark Mechanical is a nice and easy option, though it loads .step file by default as "locked" you can unlock them with a simple trick;
* import your step design in DSMech
* create a new solid (a cylinder for ex.)
* right-click on the top-most assembly name in the tree
* unlock
http://www.rs-online.com/designspark/electronics/eng/page/mechanical
1
tinkergnome 922
No STL, but the STEP files are published here.
You should be able to convert it to STL, if in doubt you can use FreeCAD for this job.
