No i just didnt use as learner The expert mode
And how do I install a firmware update ?
I know this for the old makerbot, that this was nearly the same way like this msg now
"No i just didnt use as learner The expert mode"
Sorry, I don't understand what you mean?
This has nothing to do with the firmware. But, if you want to update the firmware you do that via "Machine -> Install default firmware".
Try re-saving the file to the SD-card and try again.
@Edel: Can you please post the first ten lines of you GCODE?
sorry this was a problem on my iphone with autocorrect, which i not saw on the small display.
No i just didnt use expert mode only the fast mode
I know this form the old makerbot, that this was nearly the same way like this msg now
How can i post the GCODE or the file? it was only the small robot, nothing important
IRobertI 503
If you didn't change Gcode-flavour in cura this likely means that the file got corrupted when you saved it to the card (this happened to me yesterday). Try re-saving the file and make sure you eject the card before removing it from your computer.
