Yes it is printed with 0% infill. I'll try printing with 1.2 mm Top/Bottom Fill in order to get a even shell. Never thought about this actually.
Thank you for your help! I will update you as soon as I get the print done.
Edited by GuestYes it is printed with 0% infill. I'll try printing with 1.2 mm Top/Bottom Fill in order to get a even shell. Never thought about this actually.
Edited by GuestPrinting with more Top/Bottom Fill doesn't solve my problem. The specific regions still look the same. While watching my print i noticed that the inner shells aren't touching and seem quite thin whereas the outer shell has a solid width. My Outer shell speed is 30mm/s and my inner shell speed is 50mm/s.
Edited by Guestinteresting, if you are getting under extrusion at 50mm/s and not 30mm/s then maybe raise the temp or slow down the whole print.
I will try both and see how it turns out. Thanks!
I doubt very much it is under-extrusion; it is almost certainly printing a flat surface across a void. As a test I suggest you use the "cut off bottom" function on the advanced tab. I am a looking at your 2nd pic and what I assume is a shoulder that has the error. Using 1.2mm as your solid infill setting, I would "submerge" your model so you have about 3.5mm of the shoulder above the surface. Change your infill from 0% to 26% and run the print - sure stop it once the shoulder has printed. You should find you have a much better finish on the shoulder. A pic of the result would be useful, if it too does not print well
you can also set the flow to 105%, that is what I always use.
Raising the temp and lowering print speed didn't have any effect on the problem.
I will try your tips and see how it turns out, and update you with a few pics. Hope it will help and thanks again!
tinkergnome 917
It doesn't look like underextrusion to me. Is it printed hollow?
I think it's more a problem of "non closed top surfaces" then with small areas...?
Perhaps it only needs some infill or more top layers (and/or more shells)?
Also printing the shells "outside-in" could help.
Which slicer do you use?
