Underextrusion Problem on smaller layers
ELLOMS
Posted · Underextrusion Problem on smaller layers
I am currently working on a project where heavy use of Colorfabbs Bronzefill filament is involved.
I printed a lot with Bronzefill and consider myself quite experienced in the use of it.
Nevertheless I ran into a problem I can't solve.
On the smaller layers of my print the printer seems to under extrude quite a bit.
I also noticed that smaller layer heights have a positive effect on it as well as larger layer heights, infact I only experience this problem around 0.15 mm layer heights.
Furthermore I tried to tweak the retraction settings to see if that has positive effects on my problem. It didn't have much of an impact. I can also rule out problems with the nozzle though I changed it recently and updated my feeder system to the iroberts alternative feeder.
I am not experiencing similar problems with PLA.
But anyway here are my settings and some pictures of my problem. I hope you can help me with my problem because I am getting very frustrated by now.
Layer height: 0.15 mm
Speed: 50 mm/s
Temp: 219 C°
Wall thickness: 1.2 (0.4 mm nozzle)
Flow Rate: 104%
Retraction: 4.55mm 25mm/s
Thanks for your help!
    It doesn't look like underextrusion to me. Is it printed hollow?
    I think it's more a problem of "non closed top surfaces" then with small areas...?
    Perhaps it only needs some infill or more top layers (and/or more shells)?
    Also printing the shells "outside-in" could help.
    Which slicer do you use?
    Posted (edited) · Underextrusion Problem on smaller layers
    Yes it is printed with 0% infill. I'll try printing with 1.2 mm Top/Bottom Fill in order to get a even shell. Never thought about this actually.
    Thank you for your help! I will update you as soon as I get the print done.
    Printing with more Top/Bottom Fill doesn't solve my problem. The specific regions still look the same. While watching my print i noticed that the inner shells aren't touching and seem quite thin whereas the outer shell has a solid width. My Outer shell speed is 30mm/s and my inner shell speed is 50mm/s.
    I will try both and see how it turns out. Thanks!
    I doubt very much it is under-extrusion; it is almost certainly printing a flat surface across a void. As a test I suggest you use the "cut off bottom" function on the advanced tab. I am a looking at your 2nd pic and what I assume is a shoulder that has the error. Using 1.2mm as your solid infill setting, I would "submerge" your model so you have about 3.5mm of the shoulder above the surface. Change your infill from 0% to 26% and run the print - sure stop it once the shoulder has printed. You should find you have a much better finish on the shoulder. A pic of the result would be useful, if it too does not print well
    you can also set the flow to 105%, that is what I always use.
    Raising the temp and lowering print speed didn't have any effect on the problem.
    I will try your tips and see how it turns out, and update you with a few pics. Hope it will help and thanks again!
