Thanks for the help, I thought about cooling too.
I need to print small pieces, this one have a diameter of 10cm, but the thickness is 1 - 2 mm only. I have tried to play with the minimum time per layer, without success for the smallest parts.
I am going to try with a couple of copies, but maybe I should look for better settings too?
Should I try with a smallest nozzle (I have only used a 0.4 for now)? How to adapt settings for small prints?
IRobertI 503
It's hard to see how big the print is but I'm guessing it's quite small? If so, it's most likely a cooling issue. The plastic isn't given enough time to cool so it's a bit like chewing gum and can move around a bit as it gets pushed around by the nozzle.
Try printing a couple of copies at the same time and see if that helps.
