I am sure mine is not the only heated bed that runs on separate 120vac supply (driven with solid state relay). I don't feel it is at all more unsafe than other household appliances. As gr5 pointed out though, even higher voltage may not be safe. In Europe where a lot of UM's are sold, the AC line voltage is 230v and you'd be stuck running your heaters at that or add a costly step-down transformer.
On the other hand, I don't think I would want my hot end to run on AC because of the nature of the head motion (wire travel and fatigue), and that I am touching the head quite often. If the nozzle heater were to short out, it would be easy to get shocked. Otherwise, the DC powered hot end and bed are already included in the new machines as they are shipped. I think only the UMO lacks a HB as stock.
gr5 1,873
The UM2 power supply is designed to work with both 120VAC and 240VAC. If it was an AC heated bed you would have to either make 2 beds or use a transformer to lower the current. Also the USA Military determined that truly safe voltages must be under 60V DC or 30V AC. To make the bed AC power and also safe you might want to lower the voltage to 30V max. But now you have a heavy, expensive transformer to achieve this (and with a switch for 120V or 240V mains which adds more danger/complexity) and now it's just cheaper to use a DC power supply.
This is my guess.
