Could you check that the x/y hotend thin shafts are properly aligned, with the small wood piece that tightens the assembly not 'way too tight'. I ask because I was able to do something like the first video, because the x shaft was way too tight on my system, making a way too weird noise when homing.
Try to relax a bit the slideblock part that holds the shafts in place, not too much, just a little bit to see if the movement becomes better.
I will check into that next here. I am just to the point of wrapping up the xy bars and pulleys.
I'm done putting everything back together again. I didn't go too tight with the xy head shafts either. It's A LOT quieter then before.
Also - It's currently printing like a champ!
Thank you everyone!
- 1
bsilverwood 8
