Stainless nozzles have bad heat transfer and require a lot higher nozzle temp. Also the fans cool the tip and makes it even worse.
I printed the barrel with 0.3mm Brass Nozzle, 0.08layers and i think 40mm/s
The build up around the Nozzle is normal for this material but may have been made worse with you not using fans.
bob-hepple 59
The print has finished Not Good a lot of scaring from the glob of material collecting on the nozzle.
also I laid a brim of 5 lines wide this didn't adhere to the main body where there is a good surface finish theres gaps in the weave you can see it on the second R on the right.
this was printed at 200 I also turned up the extrusion to 110%![BronzeFill.thumb.jpg.2ed980336ec43c4a9e5c5c946626e3ab.jpg](//content.invisioncic.com/ultimake/monthly_2017_12/BronzeFill.thumb.jpg.2ed980336ec43c4a9e5c5c946626e3ab.jpg)
