Ultimaker 2 Extended - 1.0mm nozzle(toothpaste) test
RetromanIE
Posted (edited) · Ultimaker 2 Extended - 1.0mm nozzle(toothpaste) test
Finally got around to trying out the 1.0mm nozzle(Olsson block etc).
It's pretty silly looking, and I see why it's nicknamed the toothpaste nozzle :)
Handy for super quick low resolution prints though.
0.8mm layer height
230c printing temp
60c bed
15mm/s
Colorfabb traffic light red PLA
Sliced in Simplify3d
And yes, i know my fan shroud looks a mess. But it works great after I modded it with some Sugru :)
I got sick of the custom shrouds warping and generally not going well for me. I used the sugru to improve the noise/vibrations and even airflow a little on the original version.
Actually, could i paint it I wonder to improve the look?
    Posted · Ultimaker 2 Extended - 1.0mm nozzle(toothpaste) test
    Wow, what is that "hood" you've made?
    Love the dinosaurs!
    I bought the hood from a 3d printer store in Germany(can't remember the name, but the owner is registered on here i think). It's pretty great, but the clear plastic is acrylic and gets scratched up, I might replace that with polycarbonate sheets at some stage(maybe when getting the a door made up).
    The dinos are just some vase mode prints i was testing out.
    The 1mm nozzle works fine at more reasonable layer heights. I'm getting excellent PQ on single-wall "vase" prints at .25mm.
    I should add that this is at 40mm/sec speed, moving 12mm3/sec. of filament. (Bondtech feeder, 35W heater)
    Love the dinosaurs!
    I got the same top cover, I can recommend this :)
    It's been sold here
    cheers
    I'm still saving for my Ultimaker 2 + !
    Good to know!
        • 27 replies
